I modified my upper radiator mounts because the rad was too loose, bouncing all around in its perch. I cut out the old dry rotted rubber on the top brackets, and used some sway bar bushings on top of the radiator. Simple fix, now the radiator is tight, but not too tight.
Radiator Support Repair
Good idea. I never would have thought of using those.You gonna race that thing?
Nice fixBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Here I thought this was gunna be a thread on fixing a rotted out lower rad support lol
AZ cars don't rust they just dry rot all rubber, plastic, fabric & paint. I wouldn't know how to deal with a SSV (Sacrificial Salt Vehicle).Originally posted by Damkid View PostHere I thought this was gunna be a thread on fixing a rotted out lower rad support lol'88 LX (VIN#30) one of the first Built 12/86
'88 L (VIN#55753) Built 12/87
'93 GL one of the last Built 5/19/93
