It something like a GMr25. I have a question about how far the slave cylinder has to move the lever on the tranny to get the clutch to disengage. Mine doesn't move much but the pedal action is good.
Hydraulic escort gt transmission
Celebrating 25 years of festiva(s) ownership.Tags: None
This is the fork Im talking about, mine is moving about 1/2",hope that's enoughLast edited by freshtiva; 05-12-2013, 08:18 AM.sigpic
Originally posted by bobbyspider View PostIs it not disengauging the clutch?sigpic
First this isnt a "hydraulic transmission", its a hydraulic clutch linkage on a manual transmission.
I know nothing about this particular car, but do know about hydraulic clutch linkage. And yes most of them are PITA to get completely bled. Even worse, most modern hydraulic linkages have no mechanical adjustments to fudge a bit with like older systems. They have to be absolutely completely bled to within gnats eyelash in order to just function normally. I suspect you have more bleeding to do.
The exception is the aftermarket universal Wilwood hydraulic clutch linkage that I put on my Ranger. It uses a pull type slave cylinder instead of usual push type slave. So you mount it back of clutch lever instead of in front. Anyway its gotta be the easiest to bleed system I ever experienced. You basically open bleed valve on slave, let brake fluid out until you see no air, and voila, its bled. 10 minutes tops. Plus it has longer stroke than many slaves. Really. After struggling with Ford's el crappo plastic setups on their pickups, that are an incredible pain to bleed, this was heaven sent.
Before anybody mentions that Rangers had OEM internal type slave. Well most did, not all, but most. However I converted my Ranger to the 300-6 and an old three speed transmission so have clutch lever and can use external slave. I also used aftermarket all metal master mounted next to the brake master, not slanted down in impossible to get to area, like the OEM plastic master. The little 2.8L V6 was horrible underpowered pickup engine (very little torque at lower rpms), especially on a 4wd and with factory axle gearing being wrong for it. 300-6 is overkill for a Ranger, but the more appropriate smaller 200-6 and 250-6 are rare as hens teeth anymore, at least in good condition.
Yea they are a pain to blead. Are there axels and a hub on? put a wheel on and have a friend push the clutchand try to spin the wheel. Maybe that will help? But bleed the crap out of it as well, fill the res and let it gravity feed, take the bleeder valve all the way out and let grav do the work
Originally posted by Banana Bonanza View PostI know nothing about this particular car, but do know about hydraulic clutch linkage. And yes most of them are PITA to get completely bled. Even worse, most modern hydraulic linkages have no mechanical adjustments to fudge a bit with like older systems. They have to be absolutely completely bled to within gnats eyelash in order to just function normally. I suspect you have more bleeding to do.
Originally posted by bobbyspider View PostYea they are a pain to blead. Are there axels and a hub on? put a wheel on and have a friend push the clutchand try to spin the wheel. Maybe that will help? But bleed the crap out of it as well, fill the res and let it gravity feed, take the bleeder valve all the way out and let grav do the workLast edited by freshtiva; 05-12-2013, 11:01 AM.sigpic
Those are easy, don't even use the bleeders. Fill the reservoir and push the slave all the way in a few times before hooking it up. Completely self bleeds the system as all the air is forced out the pilot bleed in the master.
The remote reservoir Rangers are a royale pain no doubt, the hardest part after replacement is getting fluid from the reservoir to the master.Reflex paint by Langeman...Lifted...Tow Rig
Marcus, you will not get the same distance traveled at the slave that you have at the master. Master travel will be longer than the slave, and that imparts a mechanical advantage as well as the hydralic advantage that you get from the smaller master bore to larger slave bore.
i would expect to see at least .75" travel at the slave.Trees aren't kind to me...
Originally posted by Banana Bonanza View PostI converted my Ranger to the 300-6 and an old three speed transmission so have clutch lever and can use external slave. I also used aftermarket all metal master mounted next to the brake master, not slanted down in impossible to get to area, like the OEM plastic master. The little 2.8L V6 was horrible underpowered pickup engine (very little torque at lower rpms), especially on a 4wd and with factory axle gearing being wrong for it. 300-6 is overkill for a Ranger, but the more appropriate smaller 200-6 and 250-6 are rare as hens teeth anymore, at least in good condition.
Originally posted by freshtiva View PostIt something like a GMr25. I have a question about how far the slave cylinder has to move the lever on the tranny to get the clutch to disengage. Mine doesn't move much but the pedal action is good.
