Question about A/C
  • Question about A/C
    I read the thread discussing getting more cold out of the a/c. Reference was made to factory a/c and dealer installed a/c. How do I tell which I have? Thanks.
    Main difference: Factory used Nippondenso compressors and dealers used Sanden compressors.
      My dealer installed A/C has a sticker on the Radiator suppoet that states it is dealer installed.
      '93 Green L - ' Tiva
        Do you have the sticker that states the R-12 capacity?
          Nope, isn't in the service manuel?
            I was told 22 oz of R-12.
              IIRC the book says 1 lb 9oz or 25oz. I have been told that if you change to 134a you only need 80% of 134a to fill the system. good luck.
                I would say easiest way to tell was where the relays were.
                06 Jeep Cherokee Overland
                95 Aspire (sold)
                  25 oz .7 kg , 1.56 lbs and a bit less for freeze12 or other hybrids. 134 is the least efficient.
                  The hybrids got better fuel economy because of better efficiency than R 12. So our govment chose 134 because it was the worst they could find for efficiency- fuel economy!! Because of this a conversion works better slightly under charged with 134..some bubbles in a sight glass.
                  The best systems are original 134 systems with their bigger condensers and slightly different other components converted to hybrid!!
