original engine
  • original engine
    hmm ive been looking at different engines in the festivas on here and i was wondering if anyone knows what engine mine has in itIMAG0278.jpg it looks pretty big compared to others
    Looks like a bone-stock 1.3L EFI..
    But that's just me.
    1988 LX 5-speed
    Gone:
      Looks like a stock B3 1.3L to me as well.
        That's a 1.3. If it was a 1.6 SOHC (1st Gen) it would look exactly the same so you'd have to check the block stamping. After those you can definitely tell if it's a swapped engine, all the other B's look quite different from the 1.3 and 1st Gen 1.6.
        WWZD
        Zulu Ministries
          ok thanks for the clarification on that guys
            How much HP does the 1.6 have? And what kind of mileage does it get?
              63hp 1.3L
              82hp 1.6L
              Driven sanely, the 1.6L still gets about the same. 40+ in a 5-speed.
              1988 LX 5-speed
              Gone:
                I can't squeeze a hair more than 36 out of my b6. I have a really hard time staying out of the gas petal tho and the tranny is on its way out because of it.
                Engine in pic is a stock 1.3, with the first gen 1.6 the stock intake tract doesn't exactly bolt up, the volt holes in the valve cover are off, so you would see some kind of riggery or no bolts or resonator chamber thing at all...also all the gen1 1.6 engines I've seen say 1.6 on the intake, but I guess that could be removed.
                2008 Kia Rio- new beater
                1993 Festiva- Fiona, DD
                1997 Aspire- Babyspire, DD
                1994 Aspire - Project Kiazord
                1994 Aspire- Crustyspire, RIP
