How many of us replace the front main seal when replacing the timing belt and water pump? I was told by a mechanic that I shouldn't mess with it if it isn't leaking. I always thought it was cheap "insurance" to replace the front main seal while I had it tore down that far. I just wanted to see what everyone else is doing.
Front main seal question
I don't unless it needs done.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I'll go ahead and put 2 cents in. If you have 40,000 on a seal why would you replace it? If you have 140,000 + age on a seal why would you not replace it? The harder it is to get to a part, the better it is to consider a replacement, especially a cheap part. Alternatively, wait until it's leaking and making a big mess, then you can redo all that work to get back at it. Maybe it goes bad at an inopportune time. If you can get to it and you have the skill and tools to put it in without damaging the surfaces or seal itself, then why not?When I'm good I'm very, very good and when I'm bad I'm HORRID.
Oh, I know how to do it, I've done timing belt/water pump/front main seal at least 10 times - three times on the same festy until I figured out the crank snout was so wore it just wouldn't seal (325,000 miles). I was curious to see what everyone else was doing. tooldude - that is an awesome way to explain it - that is exactly how I look at it. I'll be changing the front main seal on #3 when I do the timing belt and water pump simply because I don't know how long it's been since it's been replaced and the car has 125,000 miles.
I get $27 after 430pm on a 40hr week.Originally posted by 1chrisapple View Postid do it not worth $15 to have to pull it down agian
That $15 part is only worth it if I can do it again under 30mins. Otherwise go to work and pocket money.
Replace it.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
