I bought the car cheap knowing it has one cylinder very low. The second cylinder only has 30psi. I just popped the head off, the piston appears to be fine and the head does do, I was expecting the valves to be stuck open or something like that but it's not. What could be my problem?? Thanks
Compression problems..
In case you don't know how to do this - remove the rocker arms or loosen the bolts enough that all the valves have a little clearance between the point where the rocker arm contacts the top of the valve stem. Turn the head up side down and fill the area around the valves with something like kerosene. Look in each port, both intake and exhaust for a wet spot to form. No wet spot, valve is good. Wet spot, valve is leaking.Originally posted by tooldude View PostMaybe a warped/bent valve that only appears to be seating well. Check if it can hold liquid.You gonna race that thing?
