4GREEN GRAB BAG
Thanks. I have to offset drill my lower fan shroud standoffs, so that the holes are farther apart. It's too late to do any modifications to my chromed fan shroud.
the holes are the same CL horizontally and the same distance in from the left & right sides. but the bottom tabs on the AT one are 3/16" longer than the MT. i wonder if an AT radiator is a little taller. there is enough tab that you could hog out 3/16 and it would bolt in where an MT shroud would.
the top of the AT volute or tunnel is 1 1/2" higher than the MT and the CL of the motor is 1 1/2" higher also.
interestingly they are both the same depth. the square body of the AT one is flatter allowing for the deeper tunnel.
F3BZ, can you please trace the hole locations for one of the shrouds and then check if the other shroud holes are in the exact same location. I need to know if the mounting locations are exactly the same. Many thanks.
I am thinking that the reason for the fan offset is due to the A/T cooling chamber being on the bottom + clearance for factory Nippondenso hoses to the compressor. There was an extra fan in front of the condensor and the hose that was attached to the hood latch support, went down directly ahead of it.Last edited by bravekozak; 12-09-2016, 11:33 PM.
i couldn't find any # for the 3 door pride spare tire cover but they did have a # for an Avella board. took a chance that i could make a Festiva one out of it. i know it would be a LOT cheaper to go to home depot but authenticity was more important than money. and there is plenty of board to make a festy one out of it. even the finger hole will end up exact. KK38668820. $22.50
Festiva board compared. i think the aspire board is for a 4 door or 5 door.
this is interesting. comparison between AT and MT fan shrouds. AT is on the left. notice how much more the blade tunnel is offset towards the driver side and also how much higher the AT shroud is. also different depths in some areas. maybe this would help for some clearance issues for an engine transplant or lowering/moving forward if you keep the stock radiator. maybe the AT flows more CFM. i dunno. lotta maybe's.
AT shroud - KK18115210B. MT - MB37615210A. $27.00 ea
AT on left.
AT on left.
I'm sure my grandson would love that. Do you remember what year(s) I would need to look for?Originally posted by bravekozak View Post1990, I am using a transfer case boot from an old Nissan Trailblaizer that I got for free at the junkyard. Fits great. I think it's leather.
Should that be Pathfinder?Last edited by 1990new; 07-16-2016, 06:44 PM.
1990, I am using a transfer case boot from an old Nissan Trailblaizer that I got for free at the junkyard. Fits great. I think it's leather.Last edited by bravekozak; 07-16-2016, 06:15 PM.
I was careless. I looked at the boot shown in the diagram above the console showing 7277 and made
the assumption that the E8BZ-7277-A at greenesalescompany was the one that fit in the console.
I even emailed them asking if it was the one that fit in the console.
Well it arrived today and it is a brand new, still in the sealed Ford package, shift boot that fits directly over shift on the floor.
I already had two of those... but now I have a pretty new one too for $35Last edited by 1990new; 07-16-2016, 05:11 PM.
