i need those green shifter bushings but i need to pay you for my last order first!!!!!!
4GREEN GRAB BAG
look for the self lubricating metal bushings.. they apparently last a lifetime and take off the ever annoying job of getting under and redoing them.. about 35$ from memory..Originally posted by kumalaba View Posti need those green shifter bushings but i need to pay you for my last order first!!!!!!Ford Festiva 1991 WA Model (5 Door)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
I look up the part numbers on the Russian website first.
Then I go to Four Green for the price.
The Phillipine website account is closed.Last edited by bravekozak; 10-22-2013, 07:05 PM.
all 5 pcs. of the windshield mouldings were available as of 10/2012. painted aluminum with bonded rubber. you'll need about 20 clips to do the whole surround. upper RH - MDA02 50 601 - $6.79 upper LH - MDA02 50 605 - $10.36 lower pc. - MDA02 50 604 - $13.57 side RH - MDA02 50 602 - $7.50 side LH - MDA02 50 603 - $7.50. clips - KKY01 50 609A - .45.
BK, I'd like to purchase the shifter bushing/5speeds if you have any remaining. Thanks. MarkOriginally posted by bravekozak View PostDoes anyone know what the Pride deco tape part numbers look like?
Search by part description "DECO".
They range in price from $4.72 to $28.00
Here are the part numbers for the upper and lower rad hoses.
I still have a few parts left from the shifter kits. I wonder if I missed anyone?
Shifter stabiliser bushings, shifter bushings, upper ball seal + some sway bar to control arm bushings.92 GL, 98k
77 Chevy shortbed
So where to we get drawings with part numbers. FourGreen's parts finder doesn't find much of what I want, and I don't read Russian.
I recently emailed FourGreen asking for PDFs and this was their response:
We are using web based Kia WPC by Kia motors so it is not easy to sending you all the PDF drawings.
If you give us the VIN numbers for the vehicles with part description, we can help you to find OEM part numbers.
Thanks,
Jane Kang
FourGreen Auto Parts
Office in Korea : +82-2-2212-9484
Fax in Korea : +82-2-2212-958488L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
F3BZ,
So is this 0.5mm-larger-diameter fewer-turns spring the answer to trailer hauling on stock Festivas?88L black, dailydriver
91L green
91GL aqua pwrsteer
this was a big disappointment. 4G showed that they had the 3 pieces of ducting for rear seat heat outlets. unfortunately, after I paid and after the box was shipped they emailed me to say they were refunding me because the LH and RH ducts were no longer in stock. these are the 2 long arms that hug the floorpan hump and dump out through a hole in the carpet under the front seats as shown in this diagram.
this system is on my JDM car and this is what it looks like in real life.
here is the piece from 4G that attaches to the bottom of the heater housing. you could feasibly run some flex tubing off this and run it under the seats. i'm just not sure yet whether it can be attached to the US housing. might require cutting into the bottom of the housing to allow air to feed this splitter. KD001 61 271B. $2.95.
I always wondered what those large rectangular holes were for. Thanks. I was going to post that as being a rare option at one time. The missing tubes look like they hang off the shifter studs.Last edited by bravekozak; 10-27-2013, 02:20 PM.
