is this even possible at all?
change spline count on stock hubs?
There's enough options out there for the stock splines that changing the spline count would most likely only be a disadvantageLast edited by Damkid; 11-06-2013, 10:52 PM.
I'm guessing you have a swap idea in mind?
basicaly you need to determine if you can get bearings to accept the new hub or have the new hub machined to match a combo that fits inside the knuckle and has a bigger ID than stock (SKF has a catalogue on PDF for download). BR11 is the factory bearing if you need to get raw dimentions.
the big question here is which trans are you trying to install? if it's the GLH, we've discussed this and you know it's not easily feasible given it's size, mounting and linkage.Trees aren't kind to me...
Not really easy, even if there's enough meat to do it. Broaching would be one way to do it, but broaches are $$$
You could ask around a few machine shops if they'll cut internal splines, but it's still gonna be costly. Your best be is going to be swapping the whole knuckle from the other vehicle, and modifying the strut/balljoint/tierod etc to accommodate it1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^^lmao
I've thought about this, could you make a hybrid axle? Use the outer joint of the Festiva/Aspire/Rio and the inner joint of ?/?/? and have the shaft between made the correct length with the correct splines on each end. I'd think a shop that cuts and resplines axles could do this.1963 Fairlane - future NSS drag car
Did I blow everyone's mind?1963 Fairlane - future NSS drag car
No, that particular route been explored plenty of times before but it's not really an economical route. Custom cut chromoly shafts are not cheap.Originally posted by Larry Hampton View PostDid I blow everyone's mind?
XTREMETHINGS did it to mate his 6-spd F40 trans after grafting a KL bellhousing to it, so it would fit in his Probe. http://www.xtremethings.com/EngineeringRefs.htm1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
