festiva pistons
  • festiva pistons
    So I was browsing the internet looking for a performance piston for my quad. I looked on some top sites. Wiseco.com etc.. on wiseco i found that they make performance pistons for the 1.8 bp engines. I also read in various internet sites stating the b6t and bp were build using basically the same internals includeing the pistons. Would i have a problem installing oversized pistons from a 1.8 bp into a 1.6 b6t. has anyone did it yet. I believe it will add more power. what else must be done if bigger pistons are added. can someone tell em anything about this, sean[/url]
    Had two 93 Gl's Sold one siezed one and parted out threw these forums. A naturally born festy lover. Bought 3 festivas but 1 might have to go, let you know soon.
    well you must realize that a 1.8 piston if bigger in circumfrance than a 1.6 so that means basically boring out the 1.6 to a 1.8, and I think someone said this can't be done because of the length of the block, and it would make the cylinder walls to thin or something.
    Why not just use a BP and get the stroker kit that brings it up to 2.0l
    Logan
      I recently purchased a b6t. now im going to autobody school, I just want to show up the rest of the students with a festiva. I was reading they were an exact fit from another festiva site. just a though since i like the pistons wiseco puts out. sean
        wisecos or similar should be available for the b6t too.
        flyinmiata sales them for the miata.
          they should be but I searched and wiseco only lists a piston for the 1.8 bp
            Wouldn't the engines in the early miata' (1.6 dohc non turbo) be useable for referencing parts for the B6T? They should be the same engine.
            HENRY
            Fast, fun and good gas mileage. 91' Festiva(RIP) and 96' Aspire(RIP). The website is no more.
