Where can I get "all" of them from? I checked Rock Auto but there is a couple that aren't very specific as to what they are. And I am having a hard time finding the seals for the mid-shaft too. Anyone have a good source? possible Part #'s?
G-series seals??
you talking about the 2 seals against the bearing on the intermediate shaft? i got them not too long ago from mazda (for the 1.6 turbo 323) seals are F002 25 744, F002 25 742, bearing is 9960 68 2063. are you looking for the gasket/seal kit for the trans?
As far as I know there's only 3 seals on the transmission?
input shaft
axle/output shafts (pretty sure these are the same on both sides of the trans?)
There's an o-ring on the speedo drive gear
There are copper crush rings on the drain/fill and reverse/neutral safety switches1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^^sounds right to me Matt
Shift shaft seal2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Ah yeah that bugger. I think it can only be replace when you have the shift shaft removed. Never had to do one1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Yea they're hard to get to. What bothers me is that it see's alot of abuse, and they stuck it on the bottom of the tranny!! I'd think it would be one of the first to go, and it's capable of draining the whole tranny of fluid! Unlike the axle seals that just drain to axle level..
I got ALL mine from Marietta Ignition when I did the MFactory install, you can call them and see what they say, didnt have any issues with getting me the right parts the first time.Last edited by zoom zoom; 03-21-2014, 12:09 AM.2008 Kia Rio- new beater
^^definately good to know, thanks
on the G- series, the boot for the shift control rod is available from green sales. E3FZ 7F110A. but the seal behind it isn't showing up on ford or mazda parts sites as available. the speedometer gear O-ring is the same as the festiva. CV shaft seals are also plentiful at green sales. E7GZ 1177D. almost all the parts for a complete speedo driven gear are shown available from mazda but strangely there is no part # for the complete assy.
