Guests & bots cannot access this forum much less have "write access"...
Account removal/delete
1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Yeah, try a Google search. Doesn't work.
+1 Funnest way.Originally posted by Prafeston View PostJason if you are that paranoid just go start posting vulgar and inappropriate things all over the forum and the mods will be forced to Block you. Problem solved!
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
Even that won't get the account deleted, just banned, but even banned members can still login but they only have access to one forum "the hole"
As Damkid stated...would not be blocked....banned yes...his account would still be here for all to see and he would not be able to ever use it.Originally posted by Prafeston View PostDude just wants his account deleted. Is it really that hard to do? Most forums you can delete your own account if you want. I've done this before. It kept all my old posts and just turned my account into a "Guest".
This site has only provided you and others here with a place to get your car fix and share with friends....so you suggest that someone do something to just upset people and make you look like a goof because why?"FLTG4LIFE" @FINALLEVEL , "PBH"
Curious, do they post there? Ever?Originally posted by Damkid View PostEven that won't get the account deleted, just banned, but even banned members can still login but they only have access to one forum "the hole"Contact me for information about Festiva Madness!
Generally no, maybe after they're initially banned and login to find out they can only see the hole..... If the banned member posts there, we tend to have fun with them depending how much they deserved to be banned lolOriginally posted by scitzz View PostCurious, do they post there? Ever?
