Changed my bros CV axels last month, 5 speed I found 1.5 quarts to be the refill after drainind is this correct and how much does my four speed hold
manual trans capacity
Never did a 4 speed but the 5 speeds are 2.5 qt.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Do you know how to check the fluid level?Originally posted by grantjp View PostChanged my bros CV axels last month, 5 speed I found 1.5 quarts to be the refill after drainind is this correct and how much does my four speed hold
Its a PITA to see the marks on the Speedo gear assembly with fresh fluid.
Because I beleive Nitrofarm is correct it is closer to 2.5 Qts, for a refill.Last edited by Pu241; 04-21-2014, 11:24 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Loosen the barrel nut, remove the cable from the speedo gear housing.Then pull the housing out and clean it with some paint thinner.I paint ONE white paint stripe along side & over, the two "HASH" marks or "De-tents" that are cast into that little housing. Once the paint is dry it will stay on there for some time for future level checking.I tried sharpie but the fluid washed it off right away.Those two marks represent LOW/HIGH fluid level in the case.Here is what I would do,drain the fluid through the plug.Pour 80 fluid oz or 2.5 qts into the case.Let it sit a minute and then push the housing in all the way and pull it back out.You should be spot on.Originally posted by grantjp View PostI had to fill it from the cable how but I didn't notice any level marks. Advance told me 3 pints
I'm probly gonna need a bookSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Cool. Its plastic I think can't I scratch it on it.
And im sure I only put 1.5 in my bros a month ago I'ma have to fix that.
IMA do a drain and fill on my four speed. Think in about using Lucas or somn thick.91 festiva L five speed red/black
74 Honda cl200
89 festiva Lx efi automatic grey
90 festiva L aqua blue parts car
Its aluminum,the reason for the white paint is a contrast to the red fluid. A scratch might not really help you see the fluid (its almost invisible when clean)Originally posted by grantjp View PostCool. Its plastic I think can't I scratch it on it.
IMA do a drain and fill on my four speed. Think in about using Lucas or somn thick.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
There is a pic some where on this site showing the mark on the speedo gear assembly, and of course in the manual.
I'll see if I can find it.
Found it, not a great pic but will have to do!
Last edited by Pu241; 04-21-2014, 06:34 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Man you guys are awesome, and Im lovin this car.
I never really cared to much about my vehicles but their is somn bout this lil car.
I could go on but I'm sure you all know.
Thanks for this forum and all who keep it alive.91 festiva L five speed red/black
74 Honda cl200
^Yes to some of us its an illness.
Which axle?Originally posted by wirebrain View PostJust a FYI.... I changed one of my axles last week and upon adding the second quart ,some of it ended up on the ground. I ended up having to drain some out of the trans to get to the right level..... 92 five speed......
Did you drain the oil from the drain plug or just let it drain when you pulled the axle?'93 Blue 5spd 230K(down for clutch and overall maintanence)
My thoughts exactly.Originally posted by wirebrain View PostPassenger side axle and I just let it drain from the axle hole.....so there could have still been some fluid in the trans...:/
will also depend on how high you jacked the passenger side, more fluid could have pooled on the drivers side depending on the angle.'93 Blue 5spd 230K(down for clutch and overall maintanence)
