Just wondering what everyone's opinion was on Marvel Mystery Oil? Was thinking about running it in the little B3 I've got. It's got 220k on it and was obviously neglected by the previous owner. Figured I'd dump some in as directed after an oil change and buzz around for a few days before changing the oil again. I used it a few times in the gas tank of my old RX7 with a little 2 cycle engine oil since the OMP was shot, but I've never had any experience using it on a valved engine. Everything I've read sounds relatively promising. Thoughts?
Marvel Mystery Oil
I prefer seafoam over everything else. Independent studies show that it's made up of 4 parts diesel, 2 parts naptha or similar yellow oil, and 1 part alcohol like methanol. Diesel makes a great de greaser and lube, naptha is the big cleaning agent in the mix, and the methanol is for water control in your oil or gas. You could make the stuff yourself at a fraction the cost.
Sent from my SGH-T989 using Tapatalk
Also depending on how badly it was neglected before you got it, I would be careful cleaning it up. Especially on the inside. You could cause leaks. Or make them MUCH worse. I'd change seals before I did any chemical cleaning. Cam seal, and both crank seals at the very least. I know it sucks to change the rear one, but it's worth it. Ask me how I know.Any difference that makes no difference is no difference.
Originally posted by bhearts View PostI prefer seafoam over everything else. Independent studies show that it's made up of 4 parts diesel, 2 parts naptha or similar yellow oil, and 1 part alcohol like methanol. Diesel makes a great de greaser and lube, naptha is the big cleaning agent in the mix, and the methanol is for water control in your oil or gas. You could make the stuff yourself at a fraction the cost.
Taken from the Seafoam® MSDS:
MATERIAL SAFETY DATA SHEET
: Sea Foam Motor Treatment SF-16, SF-128, SF-55
Sea Foam Trans Tune TT-16, TT-55 Product identifier
SECTION 1 - PRODUCT AND COMPANY IDENTIFICATION
Motor Treatment - Fuel system treatment, Trans Tune - Transmission treatment Product Use :
Chemical Family : Mixture.
Refer to Supplier
Supplier’s name and address: Manufacturer’s name and address:
Sea Foam Sales Company
12987 Pioneer Trail • Eden Prairie, MN, USA 55347
24 Hr. Emergency Tel # : 1-800-535-5053 (Infotrac)
N.
SECTION 2 - COMPOSITION/INFORMATION ON INGREDIENT
Ingredients CAS # Wt.%
Pale Oil 64742-54-7 40.00 - 60.00
Naphtha 64742-49-0 25.00 - 35.00
IPA 67-63-0 10.00 - 20.00
Below extracted from various chemical sources.
IPA/67-63-0
Is Isopropyl Alcohol, very much different from methanol and not has corrosive!
Pale oil/64742-54-7
Data Source for TSCA Definition 2008: A complex combination of hydrocarbons obtained by treating a petroleum fraction with hydrogen in the presence of a catalyst. It consists of hydrocarbons having carbon numbers predominantly in the range of C20 through C50 and produces a finished oil of at least 100 SUS at 100.degree.F (19cSt at 40.degree.C). It contains a relatively large proportion of saturated hydrocarbons.
This is outside the diesel fuel specification of C8 to C21.
Naptha/ 64742-49-0
Is a conventional aliphatic fluid solvent that boils in the range of approximately 66 - 92°C; 151
- 198°F. This solvent is used in many industrial applications such as fuel additives, paints and coatings,
industrial cleaning, and process fluids. Naphtha is composed primarily of saturated aliphatic C6 to C7
hydrocarbons with a low aromatic content.
In short you likely can't make your own.
I would be interested in these "independent studies" though.
But would suggest that a mixture of IPA and #1 diesel might make a good fuel system cleaner, used at low percentages.
Or possibly a mixture IPA and Bio-diesel would work better, again at low percentages.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Got a leaky valve cover seal but I don't think I'm leaking oil anywhere else. Plan in changing it out soon. I've always heard sea foam is super aggressive stuff so I'm reluctant to use it. This marvel stuff doesn't seem as intense.You can't polish a turd but sure as hell can roll it in glitter.
Actually, the Seafoam® is less aggressive than MMO.
MMO contains Chloro Benzene which is a very good solvent, at around 2%.
I would go with Sketchman on not cleaning out the engine itself.
I'd would use the Seafoam® in the fuel system.
Clean out the engine and you run the risk of opening up bearing and ring tolerances that currently are being held there by varnish and crud.
And as he said, depending on how badly neglected it was you could loose compression, oil control, and bearings.
But it is your car, and it is only my opinion.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Refer to Supplier
N.
IPA/67-63-0
Pale oil/64742-54-7
Naptha/ 64742-49-0
Now that is some good work!
I have a different opinion on some of the substitutes he is using, but he has done some nice work!
Good info!
Thanks'93 Blue 5spd 230K(down for clutch and overall maintanence)
