front hub?
  • front hub?
    What exactly is the name of the the part that the front wheel is mounted to.
    I have a stripped wheel bolt hole.
    I've looked every way but I can't find
    91 festiva L five speed red/black
    74 Honda cl200
    89 festiva Lx efi automatic grey
    90 festiva L aqua blue parts car
    It's called the hub. You could have it drilled out and a press in stud installed into it. Might want to have all 4 on that hub pressed in.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      Speaking of press in Festiva studs.
        Another option is to have a heli-coil installed to keep your bolts the same.
        These are not cheap though.
          Well what had happened was, when I got the car one stud was broken off flush, so I drilled "center kinda" but a lil woby sobby and to big of a bit, so I couldn't Back it out. Finally after seperating the hub from the rotor I was able to bite a small bit of the old stud from the back with vice grips. I got threads.
          74 Honda cl200
            Good going!! Are the threads still sufficient enough to hold?
            Jerry
            Team Lightning
            93 L Lightning. BP
              oh yeah 80 foot pounds of torque. sufficable
              74 Honda cl200
