there was one up for sale here a few months back. It went quickly. Haven't seen one for a long time before that or any since. They're out there, just not many for sale. All you need to do is space back a stock b3 mount iirc. So easy a caveman could do it.lol
Festiva Motor Sports
Here's a nice one too.
You can use the stock B3 passenger side motor mount on a B6T, that's what I'm currently using. Take off the whole B6T mount and just bolt the B3 mount into the 3 holes on the back of the B6t block. You'll need 3 spacers about 1 1/4"?, I got some thick brass spacers from the plumbing section, but washers would work. You'll need longer bolts, also. The engine sits a few degrees crooked, but it's totally viable. I'll take pictures if you want.
I'll bet you could do a little work on those brass spacers to take the crookedness out of it; i.e., a diagonal cut to offset the crookedness of the unmodified spacers.Originally posted by vanhick View PostYou can use the stock B3 passenger side motor mount on a B6T, that's what I'm currently using. Take off the whole B6T mount and just bolt the B3 mount into the 3 holes on the back of the B6t block. You'll need 3 spacers about 1 1/4"?, I got some thick brass spacers from the plumbing section, but washers would work. You'll need longer bolts, also. The engine sits a few degrees crooked, but it's totally viable. I'll take pictures if you want.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Stock B3 passenger side motor mount bolted on a B6T with spacers.
Yep, and a bp, I've been doing the spacer thing for years-Greg
Redneck Engineer
FOTY - '09
Just use as many b3 pieces as you can. Thermostat housing, alt bracket, water tubes, etc-Greg
Redneck Engineer
FOTY - '09
