do the cars with speedo have longer speedo cables? myne does not seem long enough
speedo cable lenght
speedo cable lenght
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Are you talking about non-tach speedo cables for tach clusters?
It should be just long enough if you re-route it around the right side of the column support. I was told tach cluster speedo cables are about an inch longer.
I attach the speedo clip to the back of the cluster first, then pull the cluster gently into position, then install the speedo gear into the transmission.Last edited by bravekozak; 06-11-2014, 07:13 PM.
I've not had any issues installing tach clusters in a non-tach cluster car. As long as the cable is re-routed properly I've been able to hook things up as required.Ian
ok got it installed! now just need to figure out why it's wiggling so muchDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
now does anybody know why the speedo is wiggling so much? checked the speedo cable at the tranny.... got a little better but not by much....Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Originally posted by ralph89891 View PostDid you insert the metal piece at the end of your cable correctly in the tranny speed sensor, its kind of like a key it goes in a certain way.
Originally posted by Chobobulous View PostIf by wiggling you mean wiggling between , for example, 40 and 45 when you are driving 43 recheck to make sure there are no super sharp bends in the Speedo cable routing and also it wouldn't hurt to lube the inner cable.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
If anyone ever wants a slightly longer cable, if I recall Aspire units are 2-3 inches more and are entirely compatible with Festy. Jumpy speedo can be related to the inner mechanism of the speedo itself in which case you'll need to try out a different one. A replacement speedo solved my problem one time. Often times though the cable is merely pinched or needs lubrication or is not fully engaged at either end. I did have a situation where the nylon gear in the tranny had split and this was causing a jump.
It's nice when you have a pile of parts on hand to swap when trying to figure out ornery things like this.
Do a drill test on it. Get a square bit to fit in behind where the speed cable goes and run the drill. If the needle wiggles\bounces, it's in the cluster, if not, it's the speed cable.1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
