I don't remember what fuel line goes where. Does the fuel feed go to the spot with the regulator (for lack of better words the gold ufo) or is that for the return.
Can I delete the charcoal canister thing.
Do I need to use the throttle cable from the Mazda? The throttle body is set back like almost 2 inches as compared to the b3 and is about a quarter open.
Edit
My wideband will be here soon but I don't have it yet. Is there a way to make the waste gate stay open so I can run with no boost until I can get a bung welded in.
Speaking of exhaust. Is the stock diameter fine or should I go up to like a 2in one.
Where is base timing for the dizzy. And I tried to put it on both ways but it only goes on one way so that's good.
Edit
