I finally got my carb festiva to turn on. Changed distributor due to no spark, timing belt jumped a tooth so I changed and adjusted the timing belt. Had little gas going to carb due to a leaky gas filter and hose; replaced.
Now that the car finally turned on a wire from the little box next to the battery started to get hot and smoke. (labeled Main). I'm assuming is has a short somewhere or do i just need to change that box. Any one had this issue before? In addition the car sounds like crapola can't rev past 2000 and turns off on me.Carb issues or can it be due to the smoky wire?
