was wondering how to take the brake roters off the festiva.... wanted to turn them but looks like you have to remove the bearings to take them off....
Brake Roters
Brake Roters
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
You are correct sir.Originally posted by old yellow View Post... but looks like you have to remove the bearings to take them off....
Some places have the ability to turn the rotors while on the car.
Or you can replace the bearing and swap in new rotors.
This is one reason why the aspire swap is so popular.
The rotors can be replaced by removing two screws.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Hi there Old Yellow, long time no see. I hope all is going well.
You are correct; after you pull the caliper remove the bearing cover/cap and remove the large nut. The rotor should pull off.
This would be a great time to install those Aspire hubs that you have.
I just need to find out if my wheels will work with the aspire bolt pattern then change all over to the aspire stuffDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
just been working on the festiva alot recently and just went back to school so I don't think i will be on much but will try to be on.... I don't know if I have any of the aspire brake parts but will have to lookOriginally posted by bolokid View PostHi there Old Yellow, long time no see. I hope all is going well.
This would be a great time to install those Aspire hubs that you have.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
I just did this. Upper and lower ball joints bolts have to come off, Strut nuts will need to be removed and the hub nut has to come off. It will all pop off. Then you have to remove the dust shield (From the back) and then the hub and rotor can be separated. Rock Auto has brakes and rotors are fair priced!! I think I got the set for $25
Festiva rotors are bolted on. The bolt heads are hidden behind the steering knuckle. The steering knuckle is pressed onto the hub and held in place by the axle nut. The knuckle has to be pulled off the hub to remove the rotor. It's a good idea to torque the rotor bolts on correctly. Last winter one of my rotors came loose a year or so after I had replaced the rotors and I had to pull the wheel apart again to tighten them. It took quite a while to figure out where the noise was coming from. I replaced sway bar bushing, tie rod ends, axle, and was about to replace motor mounts when a mechanic friend discovered the loose rotor.
Last edited by WmWatt; 09-04-2014, 08:40 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
What did the loose rotor sound like? Was it like a bearing going bad?Originally posted by WmWatt View PostFestiva rotors are bolted on. The bolt heads are hidden behind the steering knuckle. The steering knuckle is pressed onto the hub and held in place by the axle nut. The knuckle has to be pulled off the hub to remove the rotor. It's a good idea to torque the rotor bolts on correctly. Last winter one of my rotors came loose a year or so after I had replaced the rotors and I had to pull the wheel apart again to tighten them. It took quite a while to figure out where the noise was coming from. I replaced sway bar bushing, tie rod ends, axle, and was about to replace motor mounts when a mechanic friend discovered the loose rotor.
The loose rotor didn't sound like a bearing going bad. The rotor knocked and clicked as the car went over bumps, more easy to mistake for a worn or loose strut assembly (ie shock absorber).Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
