I think the rack in the black car might be messed up. Or the tie is bent. Car darts around if you're on and off the throttle a lot. The blue car has PS and since the black car has an automatic. For some reason it doesn't steer as light as my manual cars, and I've swapped racks with one out of a manual car.
Has anyone rebuilt a power steering rack?
2015 F150 SCrew - DDTags: None
Not saying it's not the rack but have you checked the sway bar to body bushings. I've had a similar issue with bad bushings.
To check for rack play try turning the wheel one way and grabbing the rack from the top and push and pull, up and down to check for play. One of mine was so bad it would pop when bouncing on the front bumper. But no i have not rebuild a rack. But i do have 3 bad efi racks all been replaced with carbed rackes. ( they seam to last forever) only down side here is no local parts place here has the right iners for that rack and there more expensive.Last edited by william; 09-12-2014, 10:05 AM.
Personally I greatly prefer manual racks, on any car. Less to break, cheaper to maintain, less stuff in the engine bay. Thinking of converting my 323 to manual steering.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I don't mind it, but it being one of our backup cars, and the girls driving it, they feel it's a little tough to drive. The BP will make up for the HP loss of the pump
