Ford Full Size Van & Truck Fuel Pump Change
Tags: None
Its similar with fox bodies. Mine had a big triangular raised portion in the trunk where the opening was in the gas tank underneath. Nope no access panel, you had to drop the tank.91GL BP/F3A with boost
Not going to work on a E-Series Van though. lolOriginally posted by jayber View Postjust 4 bolts holds the bed on1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
