as i get into detailing and bringing this GTX down to US specs for state inspection i thought i'd keep pictorial tabs on any differences i see between the mazda built gtx and made in korea festiva. first chore was to replace the JDM filler tube which doesn't have an unleaded gas pump nozzle restrictor flap with one i had from 4G that does.
first i had to remove the rear seat trim panel to access the tank inlet access plate. the trim panel felt pounds heavier than a festivas and here's why.
i don't know if all this insulation is only on the higher end JDM festivas or all of them. i like the additional sound insulation but not the weight. i was always curious about the cloth insert you see on the rear trim panel on these cars and the mazda 121s. this turns out to be a formed piece of sheet metal covered with foam and cloth. more weight but a classy touch.
and for some reason, the tank access panel on the X doesn't have the tacked on side shield that is on the festivas.
next project is replacing the excellent H4 headlamps with 80s halogen technology.
