Any ideas for aftermarket bulbs that light up the highway ? The ones I have are crap can't see to well unless I use the brights .thanks
Headlights
Have you tried aiming them using the adjustment screws on each headlamp assembly? It sounds like the lights may be pointed too far down.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
Make sure you are using 9004's also. 9007's wont index correctly in the factory housings.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I got some H4 bulbs from this guy on Ebay for another car. Here are some 100/80 watt 9004's. Just so you know that wattage is illegal but if aimed properly no one will know. http://www.ebay.com/itm/2-X-9004-Hal...4c6a57&vxp=mtrRick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
I'd be wary of running higher wattage bulbs. The wiring isn't the greatest in these cars. At the very least add a nice relay setup to pull directly from the battery.91GL BP/F3A with boost
Good point. On the other vehicle I have the higher wattage bulbs, I did install relays and better wiring.Originally posted by bhazard View PostI'd be wary of running higher wattage bulbs. The wiring isn't the greatest in these cars. At the very least add a nice relay setup to pull directly from the battery.Rick
1993 Ford Festiva
2000 Ford E350
