Headlights
  • Headlights
    Any ideas for aftermarket bulbs that light up the highway ? The ones I have are crap can't see to well unless I use the brights .thanks
    Have you tried aiming them using the adjustment screws on each headlamp assembly? It sounds like the lights may be pointed too far down.
    Axlander9289, brother of ThisVelologist
    Festivas past:
    Aqua '92 Festiva L - Sold "Dale"
    White '89 Festiva L Plus - RIP "Dudley"
    White '93 Festiva GL - Sold to thisvelologist "Frito"
    Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
    Current Fleet:
    Aqua '93 Festiva L with Aspire brakes "Dale Jr."
    Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
    White '15 Ford Transit Connect
      Make sure you are using 9004's also. 9007's wont index correctly in the factory housings.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        I got some H4 bulbs from this guy on Ebay for another car. Here are some 100/80 watt 9004's. Just so you know that wattage is illegal but if aimed properly no one will know. http://www.ebay.com/itm/2-X-9004-Hal...4c6a57&vxp=mtr
        Rick
        1993 Ford Festiva
        2000 Ford E350
          I'd be wary of running higher wattage bulbs. The wiring isn't the greatest in these cars. At the very least add a nice relay setup to pull directly from the battery.
          91GL BP/F3A with boost
            Good point. On the other vehicle I have the higher wattage bulbs, I did install relays and better wiring.
            Rick
            1993 Ford Festiva
            2000 Ford E350
