what is an oem factory flip up moon,sunroof worth?
Moon, sunroof
Ya... the 88 in our local autos wreckers has oneDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
about $100 .... a little rareDan
not that it would make much diff but i've seen a lot of flip up festiva sunroofs that weren't the OEM ford dealer sunroof. might've been an aftermarket piece similar in size. a good tip off that it's fords would be the exterior finishing caps where the hinges and latch are mounted to the glass. OEM would be round. aftermarket caps are usually square/rectangular. the OEM kit would also have a finishing trim piece inside that matches the color of the headliner. a wind deflector was available but not sure if it was part of the kit or an accessory to the accessory. also something to consider is if hinges and latch are broken since generally replacement parts are not available. a real score would be the storage bag that was offered as an accessory to store the glass in if it was removed.
removal will have to be done carefully since if it was installed correctly there will be adhesive butyl under the trim ring and it might be impossible to remove the interior finishing headliner trim without destroying it.
sure, $100 is fair if all hardware is there, glass is good and latch/hinges work.
