Looking for a replacement key for my Festiva
  • Looking for a replacement key for my Festiva
    My current key is on the verge of breaking, and no one will copy it because of it.
    I am asking all of you willing to help to look at your keys and compare them to mine, and if it matches, I would love for you to send me a copy of it.
    Of course I will pay for the key, and shipping, and pay you a little extra for your trouble.
    EDIT: Sorry I just realized that this should have been in the For Sale forum.
    There are websites that duplicate keys from a picture, not sure how it works or how much it costs but it might be worth looking into.
      TE, If I remember correctly, the key code is printed on the right side door lock. (At least that's what I've read on here). You should be able to get a new key cut with that code at a locksmith shop.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        could you put it in a key machine?
        06 Jeep Cherokee Overland
        95 Aspire (sold)
          The 4-digit code from the passenger side lock cylinder is the way to go. I've used that method numerous times after some bozo broke into my house and stole all of my Festy keys.
          Since the code is the "master," you end up with new keys that fit the ignition (and doors) perfectly, as compared to copies of worn copies of work copies over the decades.
          I've paid anywhere from $30 to $50 to create a paid of new masters with the 4-digit code stamped onto them, both of which I save in mint condition from which to make "operating" copies as needed.
          88L black, dailydriver
          88LX silver a/c, dailydriver
          4 88/89 disassembled
          91L green
          91GL aqua pwrsteer
          92GL red a/c reardmg
          1952 Cessna170B floatplane
            Just copied a key for our new festiva from the unused dealer key.... guy owned the car since it was new (second owner) and never used that key... had it copied and has been using only copies since....
            Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
            Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
            Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
            it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
            Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
            TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
            bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
            '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
            SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
            R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
            R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
            R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
            R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
            R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
              Around here most REAL locksmiths will copy a key even from a broken key. They just won't guarantee it to work, but if you're there and can test it on the spot, they will tweak it until it will work.
              "Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
              "Pedro"-88L 5-spd, B6D (built by Advancedynamix)
              "Blanca"-92 GL auto, 125K(FM8 Lowest Miles)- B6 daughter's DD
              "Tractor Blue"- 89 L auto, 110K
              "Chester"-88 LX, runs but not street legal
              "Wenona"-89L parts car
              "Flame"- 89 LX 5 spd ,parts car
                Sometime in my jeeps life it has been rekeyed by someone. I did not know about it. I lost my keys to it. I thought oh no problem. I'll get it towed to the dealer, they will cut me a key, ill be on my way. A 200 dollar mistake, whatever. Well they looked at it and told me they couldn't make a key because it no longer matched the vin. They would be more than happy to rekey the entire car for 800 dollars though.
                I couldn't justify that at all. I towed it to a locksmith. He said he would do it for 180. With a 30 dollar cash discount. 45 minutes later I had a key. He had extra christmas money.
                95 Aspire (sold)
                  I've clamped a blank together with the original, stuck them in a vice and filed it successfuly. The Festiva lock cylinders are retained by the lock faceplate and are really not meant to be disassembled. Phone the dealership to see if you can get a key code for your VIN. Good luck.
                    I cut keys here at work and unless the key is twisted so bad it wont go in the machine I dont think it would be a problem.
                    N3WBI3
                      At one point in the 25 years that I've owned Festivas, I owned two Festivas which used identical keys.
                      Sorry, I would have helped if I could; I compared the picture to the five different Festiva keys that I have, but none of them is an exact match.
                      The cost of getting a matching key copied at Wal-Mart and mailed to TroqueEffect, as compared to the cost of getting a locksmith or dealer to make one is a big chunk of change.
                      If he takes the chance on getting his copied and it does break, it's immediately a bigger problem.
                      As many Festiva keys as there are in the possession of member on the forum, surely someone
                      has one that matches the one in the picture.
                      I just called the local Ford dealer and was told they cannot cut a key for a vehicle older than 5 years. Was told they use a local locksmith for older years and they charge about $35.
                        I've had Mustang keys made at a Ford dealership using the VIN. I would think they could do the same for the Festiva, Maybe.
                        ~Jeff
                        1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
                        1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
                        2003 Mustang GT 5speed
                          I'm sitting at a Ford dealership's parts counter right now as
                          I read this thread. Ford only has key codes available for 10 years.
                          So right now they only go back to 2005. Next year at this time the
                          codes will only go back to 2006.
                            That sucks.
                            Thanks everyone.
                            Looks like I will just pull all the locks, and the ignition from the 88LX and swap it over to my 91' once I get a warm enough day to do it.
                            I will just keep driving the Monte Carlo in the mean time.
                            Sucks on gas mileage, only got 21 MPG with just under a quarter of a tank for highway travel. Rest of it was allot of stop and go in suburbs.
                            Will see what it gets with the entire tank dedicated to highway travel when I go to see my girlfriend tomorrow.
                              Ill cut you a copy mail that sucka to me
                              N3WBI3
