Do 14" tires fit without rubbing
  • Do 14" tires fit without rubbing
    Can I put 14 inch tires on the stock festi suspension without rubbing ? I have all the parts to do the aspire swap but not the wheels. I can not find any 13's. They always get snatched up before I get to them.
    It depends on the height of the sidewall. I would think a lower profile 14 inch tire wouldn't rub. I have fairly tall 175/70R13's on my Aspire swapped Festiva, and they do not rub. I would recommend using this site http://tire-size-conversion.com/tire-size-comparison/ to find a tire that is close in circumference to the stock 145/80R12 to prevent rubbing and ensure speedometer accuracy, then see what tires you can buy in that size. You may have to play with the numbers a bit to find something in your desired price range, but I'm sure there's something out there that will work.
    Axlander9289, brother of ThisVelologist
    Festivas past:
    Aqua '92 Festiva L - Sold "Dale"
    White '89 Festiva L Plus - RIP "Dudley"
    White '93 Festiva GL - Sold to thisvelologist "Frito"
    Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
    Current Fleet:
    Aqua '93 Festiva L with Aspire brakes "Dale Jr."
    Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
    White '15 Ford Transit Connect
      165/55-14 is the ideal 14" tire for these cars.
      91GL BP/F3A with boost
        Works for me! :-)
          I have 165/60-14s. I also have fms springs which lower it a little. Mine do not scrub unless I go over a bump while turning.
          Edit
          I got all four for right around 300 bucks. Bridgestone potenza
          06 Jeep Cherokee Overland
          95 Aspire (sold)
            I just called a guy with some honda 13's with new tires for 125.00, Gone right before I called. I think I am going to have a lot easier time finding 14's. Thanks for all the input.
              If you have a 14x5.5" wheel in high offset (40+) you'll scrub less than you would with a 14x6" wheel in a 35 offset, which normally is enough to push the tires into the fender well. The 14" equivalent to the 12" OEM tire is a 165/55R14.
                165/55R 14" is a tough size to find. lotsa options in the 185/60 size which is only slightly greater circumference over stock with better road holding potential. Agree 5.5 wide is the ideal , think Miata!
                  I ran 185/60/14 on an Aspire.... Don't know how they would do on a Festiva
                  Besides my festiva said it came stock with 165/70/12 tires
                  Sent from my iPhone 5s using Tapatalk
                  Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
                  Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
                  Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
                  it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
                  Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
                  TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
                  bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
                  '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
                  SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
                  R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
                  R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
                  R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
                  R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
                  R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
                    165/55-14 tires fit perfectly without rubbing.
