looks like my car might need a new axle, I think from the way my tire leans and is worn uneven and was wanting to know if the Aspire rear axle would work? I already know I am going to do the complete Aspire rear break setup on my Festiva and what do I need for the complete swap and do I need the Festiva or Aspire axle?
need aspire break info for festiva
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Hey old yellow. When it comes to the aspire rear you use everything even the break lines, and ebrake cable from a 2 door. Your festiva axles will work. Im running a b8me swap with aspire front spindles, calipers and discs. For the rear, you use rear dead end ( drum to drum). You can run your festiva cv axles with front aspire hub as long as you have aspire tie end rods and brake lines. Hope this helps. Pm me if you need more info
Sent from my LG-H811 using Tapatalk
Festiva or Aspire rear axle?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
ok.... I will take pictures of my tires and the uneven wear..... don't know what would make tires wear in less than 6 monthsDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
I'm pretty sure that by axle he meant the beam, I used to misuse the word in reference to the rear swap all the time91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Adjustable VW MK2 front suspension and Aspire disc brakes
Aspire rear axle and drum swapped with adjustable KYB rear suspension
LOOKING FOR RUST FREE SHELL IN CALIFORNIA
Poor camber in the rear? Not 100% sure how the rear of these are set up though.
Is it possible there's a camber adjustment bolt out of alignment or something?
Just throwing it out there...maybe I'm completely wrong. It'd be nice to fix your
current rear setup instead of having to change it all out though.1993 Festiva - White/Black - 5 speed
Axle isn't wrong. It is technically a trailing axle. They are both trailing wheels but since they are a set they are an axle. They are connected by the axle beam.The Festiva Store
all spelling correct? check. all definitions and terms correct and verified by at least 3 impeccable sources? check. all grammar, sentence structure and punctuation follow accepted standards? check. OK then. it's safe to post. can you look up nitpick? maybe i'm just overly sensitive to criticism but anymore i'm getting scared to post until i do all the above.
Driver's side tire
Passenger side tire
Sent from one of my 2 iPhones using TapatalkDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
...Last edited by Flyin4stroke; 07-26-2015, 07:52 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
