So, I borrowed a friends truck and went to pick up a cargo trailer that is in bad shape and needs a lot of work.
After working all day to get it out of where it was parked, and getting tires right, I took it for a test tow. It would bounce up and down by the time I hit 20-25, so much so that I felt if it increased anymore it would lift the rear of the truck off the ground.
So, I left it there for next week.
When I was driving a tow truck, if I had experienced this, I would have thought my boom was too far out, and I needed to draw it in closer.
There is a tire changer in it, and it probably isn't perfectly balanced, but it is over the axle. There is some random stuff in the forward section, but nothing very heavy. Still, I would think the center of gravity was forward of the axle a little. Most of that IS on the drivers side of the trailer though.
Also, I admit I didn't think about how level it was. I THINK it was fairly level, but didn't check very carefully either. READ, I am capable of being tunnel visioned and ignoring something right in front of my face until someone points it out
So, what are some of the causes of that kind of bouncing? I was thinking of trying to shift that load a little forward some more. Am I on the right track, or is there something else to look at?
Thanks in advance!
Thanks in advance!
