found a bp engine.... sucks because I already pulled a b8-me and am already mounting stuff up. can I just swap the head later on or do i need to do other stuff. Doesnt the bp have oil squirters under the pistons? The BP has VICs too so would that do require anything on the block?
escort bp engine
Be happy with your b8me. It's a perfectly fine engine. I'll build you a custom intake manifold and maybe a turbo exhaust mani if you really want.Originally posted by Meepersly View Postfound a bp engine.... sucks because I already pulled a b8-me and am already mounting stuff up. can I just swap the head later on or do i need to do other stuff. Doesnt the bp have oil squirters under the pistons? The BP has VICs too so would that do require anything on the block?
That's the easy part. Do you have a picture of your intake attached to your engineOriginally posted by Meepersly View Posthow much for an intake? Would be nice to have one where I don't have to move the engine mounts forward so the mani doesnt bump the firewall.
88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
BP has stronger crank, stronger rods, stronger block, oil squirter and a different oil pump and water pump. The heads do swap back and forth, but the engines are not created equal.Last edited by Advancedynamix; 10-20-2015, 01:07 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
