escort bp engine
  • escort bp engine
    found a bp engine.... sucks because I already pulled a b8-me and am already mounting stuff up. can I just swap the head later on or do i need to do other stuff. Doesnt the bp have oil squirters under the pistons? The BP has VICs too so would that do require anything on the block?
    88 Ford Festiva LX "Miogi" B8-ME swapped.
    93 Ford Festiva L "Haywire" Rat infested trashcan WIP
    Be happy with your b8me. It's a perfectly fine engine. I'll build you a custom intake manifold and maybe a turbo exhaust mani if you really want.
      how much for an intake? Would be nice to have one where I don't have to move the engine mounts forward so the mani doesnt bump the firewall.
        That's the easy part. Do you have a picture of your intake attached to your engine
          Will this work
            [ATTACH=CONFIG]18690[/ATTACH]
            Will this work
            Look at all that space you have above your intake for a water air intercooler. Are those 2 part manifolds?
              I think so
                Can't remember because the festiva has been sitting for a couple days waiting for parts I'm looking at it tonight
                  BP has stronger crank, stronger rods, stronger block, oil squirter and a different oil pump and water pump. The heads do swap back and forth, but the engines are not created equal.
                    Well probably just going to stick with my b8me then
                      B8ME is a great engine.
                        I love the way it looks but I did want a dohc engine. Maybe later on I will get another car I can swap a b6 into
