Can i fit
  • Can i fit
    Hi guys anyone ever fit 14 inch rims on without tires rubbing if so what size tires i have the chance to get a nice set of 14 inch rims but dont wanna modify the car any help would be appreciated thanks everyone [emoji1]
    Sent from my LGLS991 using Tapatalk
    I have 165-55-14 on Miata wheels on mine. My fenders have the inside lip rolled from using larger tires. No clearance issues at all.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      Do u have to roll the rear and front fender edges in or just rear ? How bad is it on the bumps does it hit ? Can u post how far a pic here so i can tell how far i have to bend it in ?
        I don't think the 165's would need the fenders rolled depending on your wheels.
        Jerry
        Team Lightning
        93 L Lightning. BP
          I have 165/55-14s on 6"-wide wheels; no need for fender rolling in the rear. I can't think of any size tire we would use that needs fender work on the front.
            I am running 175/65/14 without rolled fenders.aftermarket 4x100 Prime wheels
              I had rubbing issues with 185/60/14's on the rear before. Those were the reason the lip was rolled.
              Jerry
              Team Lightning
              93 L Lightning. BP
                If your wheel offset is above a 32mm, and your wheels are no more than 6" wide, you will not rub the stock fenders with 165/55/14 tires. These tires fit the Festiva very well, and are actually a tidbit smaller than the 155/80-12 tires.
