Does anyone know if there are any other cars that use the same VAF as ours? My VAF has been modified and im unsure if it is still is working order and would like to go out to pick n pull and grab one to test. there are no festivas at my local yard though
VAF Interchangeability
Festivas have MAFs, Aspires have VAFs. did I recently read on the forum that Miata gen1 MAFs were the same as Festivas, or the same as B6D ones like on the Capri (which would make more sense)?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
B6d would make more sense but I bet they could swap as long as if they were adjusted properly. That's right for some reason I thought the aspire had a vaf. Probably due to them sharing the engine.
Sent from my Z936L using Tapatalk88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
Done some research and if you look at re-manufactured air flow meters for ford festivas they are the same part number for all the non gt 323's, lots of protege's, first gen Toyota MR2's (AW11) and miatasOriginally posted by bheartsWhat is one man's trash is a festiva owners upgrade. Lol
Originally posted by wisconstiva View PostAspires have mass air and festivas have vein flow meters the b6 is the same.i used a 2.2 Mazda mx6 one because it was bigger just swapped the guts from the festivas into the mazdas meter90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by navdoc101 View PostYour just getting old.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I used a 323 b6 single cam vaf meter and it worked.i know you can swap ttge festys vaf internals into different meters that are larger and it will work.my festiva I had in highschool I used a mx6 2.2 vaf but swapped the festys internals into it.its just a chip board inside from what I remember
