ECM compatibility with "88 engine swap into '93 body?
  • ECM compatibility with "88 engine swap into '93 body?
    I have a 1988 Festiva with low miles, however it was a Chicago car and is burdened with lots of rust.
    I am considering swapping that engine/trans into a 1993 body. (dead engine).
    Anyone have an idea about compatibility of the 88' vs. 93' ECM "computer" ?
    How close to just switching them (plug n' play) can I get? Or is it even necessary?
    *The older car is carburetor/mechanical fuel pump and the newer one is Fuel Injected/electric fuel pump in tank.
    Never buy a car you can't push!
    1988 Silver / 1989 Black / 1992 white / 1993 white
    There is no compatability. You use the 88 long block, as in block and head, with the 93 intake manifold and everything else.
    91GL BP/F3A with boost
      Thank you!
      I am starting to see a plan coming together for this summer.
      Knuckle busting and cussing!
      :woc:
