Hydrographic/Dipped Coming Soon
How well does that process hold up with engine heat?Last edited by TominMO; 03-16-2016, 08:08 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Oh, I thought it was some kind of wrap or something. If it's a process that uses engine paint, then it should be fine.Originally posted by ralph89891 View PostThe valve cover was painted with engine paint, but im still going to test it. Ill run it in my car for a week and update yall.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ah, gotcha, thanx.Originally posted by ralph89891 View PostThere is a film process. So essentially the item was painted a base color, the film was applied on top of the base coat, and clear coated over.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yeah the film and clear will hold up on anything that regular paint will withstand heat wise. The vc doesn't get very hot so you'll be fine.
That black and wHite sticker bomb looks good I've seen the color one but not black and white.
