I have an oil leak and I'm not sure where it's coming from, I do know that the oil pan gasket needs to be replaced and I've gotten the valve cover gasket as well, but it looks like it's coming from below the valve cover.o What is known to cause problems in that area?
Oil leak
Oil pressure sending unit. I've seen a few leak. That sounds like the location your describing.-Greg
Redneck Engineer
FOTY - '09
Actually it looks more to the right right where that other part is underneath the distributor, I'm not sure what that part is
Can you please tell us more about your Festiva: Year; 4 speed, 5 speed Auto; L, LX, LPlus, GL;
It helps if you add that information to your signature so everyone sees it in every post you add.
Since you mentioned that it has a manual fuels pump, I assume it is an 88 or 89 manual trans.
Also how many miles on the engine?Last edited by 1990new; 03-19-2016, 09:29 PM.
If you can wiggle the fuel pump then I would say that is the problem.Originally posted by Jeffs89festiva View PostCan the fuel pump be the cause of the problem, I can wiggle the fuel pump. I can't really see under it I've felt oil there, and it doesn't seem to be the valve cover gasket.
As far as I'm concerned, EVERYONE needs one of these for their vehicle(s)
