Bought a B6T Turnkey!
  • mikemounlio
    replied
    Originally posted by shadetree View Post
    Watch the wideband ! That's the answer .
    Can i run a wideband on my fender exit open downpipe? It would be easy for me to weld on a bung and mod the open exhaust to fit the new turbo.
  • shadetree
    replied
  • mikemounlio
    replied
    So lets say i get the new turbo before i have time to get it tuned and going good. Could i run the turbo on the rocket chip up to a small psi? Just to get the car moving again?
    I will have the t25/t28 hybrid turbo mid next week. Still gotta pick up a laptop, adapter wire in the ecu and get a Saturday set aside to have it tuned. Would i be able to run the car just on the new turbo?
    Its parked for now and i have other rides so its not life or death but i miss driving it already.
    ps gotta have it done by june 22
  • mikemounlio
    replied
    Rx7! I'll look into it! Thanks man
    Sent from my SM-N910V using Tapatalk
  • bhearts
    replied
    Although. It's not a terrible investment getting new ones, just so you know they are pre flow matched
  • bhearts
    replied
    Originally posted by mikemounlio View Post
    Yeah that! What's a decent but not junk injector? Or is there any plug n play from another car?
    I'm looking at 700cc injectors though. Do I can run ethanol. I know people run rx7 injectors, those are like 470 or something.
  • mikemounlio
    replied
  • bhearts
    replied
    250hp to maybe around 300
    So like 400-500cc injectors.
  • mikemounlio
    replied
  • bhearts
    replied
    i have a fully programable ecu sitting waiting. it came out of a big turbo b6t built.
    By all means then. What size are you looking at?
  • mikemounlio
    replied
    Originally posted by bhearts View Post
    How would you control bigger injectors
  • bhearts
    replied
  • mikemounlio
    replied
    Im getting a decent turbo finally! Ill be going for about 250hp out of a gt25 gt28 hybrid turbo.
    SHould i upgrade my injectors? To what is the question?
  • mikemounlio
    replied
    Friday night on the way home i really hit some overboost way to hard. I could tell the car hated it. Saturday when i started it you could hear the turbo was gone but on its last leg. So what did i do i went for a ride until i had to get the truck and trailer. The turbo held together longer then i thought it would. Finally it let go in town but only after its hardest pull yet!
    Got the replacement turbo on Sunday along with the stock down pipe. Boost creep is now much better. I didnt port the wastegate tho went to look into buying house #2 so that cut into my day quite a bit.
    The car is back to running and now in my wifes hands. So maybe it will last a few days now!
  • Advancedynamix
    replied
    You can have a flange welded to the stock manifold. That will allow you to cut out the cracked part of the manifold (trust me, it's cracked). You don't need to weld the stock gate shut. Just leave it all intact. You can even leave it functional.
    You'll have to relocate the O2 sensor to post turbo, which is a good idea anyway because they can and do come apart and destroy the turbo.
