who has an Aspire? What are you running for headlights? stock headlight housings are so cloudy and usless now even on high beam.... low beam is basically off...... headlight restore on outside of bulb housing doesn't work at all
Aspire Headlights
Aspire Headlights
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Caety runs a 4300k hid kit from VVME. Had to re-aim after install but they work well. I haven't swapped mine over yet, but have been looking at a housing swap from a LexusTrees aren't kind to me...
I just bought new ones from eBay. And Dorman makes the plug so you can also replace those.Originally posted by old yellow View Postwho has an Aspire? What are you running for headlights? stock headlight housings are so cloudy and usless now even on high beam.... low beam is basically off...... headlight restore on outside of bulb housing doesn't work at allSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I dont know how expensive new ones are, but If your willing to take the time and spend the money what worked great for me on a different car with very cloudy headlamps was this: oh, it doesnt work if they are fogged up with water inside. Thats a different problem. Is there condensation inside the lamps or just oxidation on the outside? This only works for oxidation: remove headlamps. Buy 600 and 800 grit wet sandpaper. Soak them for 10 minutes. While they are soaking clean the headlamps with soap and water and rubbing alcohol. then start sandin with 600 grit under running water from a tap in a sink. Have the bulb still installed so you dont get water inside. Sand and sand till it looks super clear under running water. Dry it off and check if there is anything else you want to sand out. If not then sand with 800grit. With the 800 your only taking out the 600grit scratches. Once you think their gone dry it off super good. Tape and mask off what you dont want paint on. Then take preferably a 2 component clear coat and spray the headlamps. I paid $30 for a 2k spray can from an autobody shop. I did 3 coats, waited an hour and then stuck them in an oven at 120f overnight. Good to go the next day. Super hard and lots of UV protection. Its ultraviolet light that oxidizes them. If you use a cheaper 1k clear it will still work just fine, try to get a more autobody type rather than home depo rustolium... The main difference is it will take longer to dry and be less durable from rocks. I also bought 3m heatlight tape and installed that overtop of the clearcoat, that may be overkill but i think it will deflect rocks better. It cost me a total of $28 for the sandpaper and paint, $60 for the headlight tape that did 4 headlights and i still have some left over.
Plastic Headlamps come with a UV protective coating. Over the years it degrades, rock chips penetrate the coating and oxidation spreads untill their cloudy. Sanding and polishing them works but it removes the UV coating and does not replace it. If you just sand and polish like with toothpaste or sos pads or any polish kit you will have to do it again in a year. Thats because there is still no uv protection. Automotive clear coat weather its 1k or 2k has uv protection and will prevent the oxidation until it chips or wears through.
My solution was to just buy a new set of headlight assemblies. It was maybe $100 and made a large difference at night.
Next help was getting the Silverstone bulbs one notch above oem. not the super bright ones.
The hardest part of new headlight assemblies is re aiming them.
$100 for 2? Thats real cheap and a better solution than fixing them for sure! Where did you get them from? I did what i said to my civic because they were $200 each new. So i spent $100 and 3 hours instead of $400 and 1 hour. Brighter headlights make a huge difference but it is very, very important to aim lights after installing new ones or even new bulbs.Originally posted by rmoltis View PostMy solution was to just buy a new set of headlight assemblies. It was maybe $100 and made a large difference at night.
Ya... o'riliys sells whole new headlight $250 per side... eBay I got NOS headlamps.... both sides for $300 to go on the SE but won't want to spend that much for dad's work car
Sent from one of my 2 iPhones using TapatalkDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
