ECU Wiring Help needed bad!
  • ECU Wiring Help needed bad!
    So the capri ecu has a ton of wires coming off it. The harness connects back into the other harnesses and dang im lost.
    Im gonna have to cut the old stuff out at points or something.
    I have my new ecu ready to go. Do i just just off the capri motor management stuff and run the new ecu for that stuff? Just run a remote to the new ecu from the old one.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    Im just lost as to what to do here. Any help would be great
      I got it now! Stock ecu stays. I will run the cas, injectors, tps, map sensor off the microtech. all other wires stay put!
      Sound about right GUYS
        That's what I'd do. At least for now
          Then you can start weeding out the original wiring harness to clean things up
            I just wish i had looked at it in detail before i started pulling stuff apart. But i got it now. Will have it adjusted tomorrow. Just sucks i wasted a day when this close to race time!
