just got car back on road, now car is acting up again. Now its idling revving and pulling without pressing gas. when i come to a stop it sounds like it got the gas pedal pressed at max. ive suspected the carburetor since the beginning. although i am not real familiar with carburetors and the many pieces that makes them work. ive checked the vaccum hoses and everything seems to be good on that end. after inspecting i noticed that the throttle body is wide open and will not close with the engine off, could this be the cause. i really really think the carb needs to be rebuilt/worked on
high idle
The TV can't be WOT, you're seeing the choke plate. That's normal. Go to the back passenger side of the carb and look for a white knob. Unscrew it 5 full turns to start. Then borrow a tach or ignition tester (with the gauges) and adjust as needed.
If you're in Marion PA, I might be able to road trip out to meet you and diag.Trees aren't kind to me...
Make sure the secondary is closed fully. With the engine idling, use some carb clean or brake clean and a straw and poke around the base and throttle linkage. There may still be a vac leak.Trees aren't kind to me...
