I've been unimpressed by low dollar Kumho tires lately. I've seen several sets come apart internally with only moderate use.
14 inch rims on stock?
I will be going to the federal 595 tire soon on OverKILL. I hope they are good tires because this car has a bit of power behind it and i dont want to buy nito tires very often.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
That's a 165/55. Maybe you were referring to an earlier post? I think Ecstas are not low-end tires. V-rated, however only an A for traction, not AA. I've always had good luck with Kumho Solus.Originally posted by ryanprins13 View PostLast edited by TominMO; 11-21-2016, 06:26 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Oops, i missed that we were talking about 155's. Sorry.Originally posted by TominMO View PostThat's a 165/55. Maybe you were referring to an earlier post? I think Ecstas are not low-end tires. V-rated, however only an A for traction, not AA. I've always had good luck with Kumho Solus.
165 was the stock width of these cars though. Do you want 155's for less rolling resistance or something?
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 11-21-2016, 06:40 PM.
That Kumho 14 165 155 ratio sidewall has a short sidewall and so an overall diameter a full inch less than my 13 155 80 ratio tires on the aspire.
So for $10 plus a tire more, you're reducing your gear sizes- not bad in town but less mpg on the road or with an AT especially,
and your tire will go flat sooner if you have a slow leak out in a blizzard someday with the flu. No fahren, fahren fahren off der Autobahn.
I can't say for sure but I'll bet a similar 13 and tire weigh no more or maybe less than a similar 14 rim and tire, and you can get a more narrow tire with smaller rims..
Just bought some 165 80 13 tires for the front of my Accent, for the same style Honda wheels-
and that wider than 155 in back because it's a 1.6 motor and heavier car, by 200 pounds over Aspire. A huge tire overall diameter wise, but the Accent 5th gear is just a little revvy for my liking, and they went to 14 inch in later years . 14 inch Escort wheels on the back pictured below with 155 width tires I got dirt cheap, and the original steel fronts, 175 mm, so the stock 70 ratio is huge
I think you can see the diameter of the 13" front wheels is slightly more than the back 14's These cars are also 4 x 100 if you've bought stuff for an Aspire and escort alloys will bolt right up.Last edited by harpon; 11-21-2016, 07:41 PM.
No I'm happy with my 165 V-rated AA Economists! Just joining in the conversation because I didn't know 155s like this existed. IMO the V-rated 165s are the better tire overall, esp. on the rear where tire wear is less anyway. I could see having Vs on the rear and Hs on the front (for better wear), just to help ensure that the rear didn't slide out on me. This would be for a DD application, not super-sporty. Charlie will probably chime in with why that's a bad idea.....Originally posted by ryanprins13 View PostOops, i missed that we were talking about 155's. Sorry.
Last edited by TominMO; 11-21-2016, 07:37 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I figgered it probably was. :-) Details please? What could possibly happen?Originally posted by bhazard View PostThat's a bad idea Tom.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
What hazard said and when it comes time to rotate tires itll get all wackyOriginally posted by TominMO View PostI figgered it probably was. :-) Details please? What could possibly happen?
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Yeah, I could see that....but with Hs on front and Vs on the rear, they might all wear out about the same time.Originally posted by Festiver View PostWhat hazard said and when it comes time to rotate tires itll get all wacky90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I wouldn't worry about that so much a set of 400 wear tires and I'd imagine they'd last almost forever lolOriginally posted by TominMO View PostYeah, I could see that....but with Hs on front and Vs on the rear, they might all wear out about the same time.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Speed and wear ratings don't necessarily coincide.Originally posted by TominMO View PostYeah, I could see that....but with Hs on front and Vs on the rear, they might all wear out about the same time.Trees aren't kind to me...
Last edited by Advancedynamix; 11-22-2016, 11:52 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
