The Aspire 5 speeds are piss ass junk... i had an Aspire with 40,000 miles and the transmission blew up... was drove by my grandma it's entire life to the store and when she sold it to dad it was in mint condition! Dad drove it just the same way nice and easy and 20,000 miles later it blew up... this engine has seen 5 transmissions since than always drove the thing nice and easy... the thing that made it worse was using ATF in a manual transmission... we switched to 75w-90 gear oil and haven't had any problems so far... this has been the best transmission so far
I bought an Aspire for it's engine, however......
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
The SE I sold to ThisVelologist had 20W50 racing motorcycle oil in it, and ran fine. AFAIK it is the original tranny, and has ~185K miles on it. I inherited a lot of repair records when I bought the car, and it was all normal maintenance stuff.
Maybe the Aspire trannys are more sensitive to what fluid you put in them. Some specific part may be different than in a Festy tranny, and that part is more prone to fail with ATF, or low fluid.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I beat the snot out of mine.... No issuesTrees aren't kind to me...
I tried searching, but not much luck. What would need to be done to install an F Series from a 323? Are the gear ratios much different than the Aspire E series?Rick
1993 Ford Festiva
2000 Ford E350
Originally posted by Eaglefreek View PostI tried searching, but not much luck. What would need to be done to install an F Series from a 323? Are the gear ratios much different than the Aspire E series?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostF series is geared lower than Festiva; about the same as Aspire E series, IIRC. Festiva E series is best for MPG.Rick
1993 Ford Festiva
2000 Ford E350
Originally posted by Eaglefreek View PostI was inquiring for an Aspire. I understand a Festiva trans in an Aspire makes it a dog and doesn't help the MPG.
According to Matt Dickmeyer, the Aspire exhaust mani is poorly designed and actually counterproductive, and the Festy one is better. You could stick a Festy mani on there as a slight upgrade, or better yet a Dickmeyer mani! (Worth about 6 HP.)90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by reddragon View PostThat white 2 door Aspire would look good with Initial D liveryBen Rogers, Admin of the
Facebook Group
'93 Festiva GL "Frito" (Travelled in 36 US States & 4 Canadian Provinces)
'91 Festiva L "Barry Bluejeans"
'95 Dickmeyer Aspire SE "Dortmund" (SOLD to jbibb1)
'91 Festiva L "Fermina" (SOLD to Hulspowered)
'93 Festiva L "Tallsmallcar" (SOLD to Stretch and Skeeters_Keeper)
Watch "It's a Festiva", my short film!
It's better to drive a slow car fast than a fast car slow.
^^ Lookin' good!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Facebook Group
