Looking to put together a good reliable daily driver with stock engine - want some options about the stock brake system - is it adequate for normal use? in an emergency situation is it safer to have an aspire brake swap? or is it not worth the trouble for a DD and i should just go with good stock parts?
How necessary are upgraded brakes for DD?
In an emergency situation it is better to be in a tank. But seriously I have driven well over 100K miles in my Festivas with stock brakes with no problems. I have also driven 100's of thousands of miles on cars with 4 wheel drum brakes with no accidents. Aspire brakes will stop you faster.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
'93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
'91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
You can certainly get by with Festy brakes, but yeah, the Aspires are noticeably better for stopping power. Plus it's much easier to change the front rotors; and the rear spindles have the castle cover/cotter pin arrangement, to keep the spindle nut reliably in place (like on 93 Festys).
Also, the 4x100mm bolt pattern gives you more choices for wheels.
Safety-wise, the most important point of course is to tighten the nut behind the wheel.....90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Sure but why would you want to? You could re-drill the hubs and drums for the 4 x 114 pattern. You might make history if you did. There are much more choices for wheels in the 4 x 100 size.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
Driven a long ways in my festiva, over 150k miles and with properly functioning front brakes i never wanted more. Its stopps faster than my brothers cavalier and stopps as fast or faster than my 2002 honda civic while towing the same trailer. Done lots of towing with it and never worried about it.
Just like any brakes you have to make sure to service them often enough to keep sliders from sticking and make sure the pads dont get glazed.
Probably more important is making sure your tires are good.
If you want to upgrade and keep the 114.3 pattern, use Capri front brakes. and if the xr2 isn't enough, that can then be upgraded with Nissan rotors and calipers from the Sentra.Trees aren't kind to me...
This sounds like a winner for me. I wonder if all of that will clear my wheelsOriginally posted by FestYboy View PostIf you want to upgrade and keep the 114.3 pattern, use Capri front brakes. and if the xr2 isn't enough, that can then be upgraded with Nissan rotors and calipers from the Sentra.
You're the man!
Capri brakes Will not clear your 12" wheels. You need at least 14" from what's been said on here.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Stock brakes are fine for DD. I did many hundreds of thousands of miles on them. That said, I am Aspire swapped for about 5 years now, and I ain't looking back. Better feel, more mass for stopping and easier to maintain.Contact me for information about Festiva Madness!
As long as your wheel and tires aren't much heavier than the stock combo, you'll be just fine. I didn't notice a major difference when I swapped to Aspire brakes.Rick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
