Hey guys so I guess I locked my hatch some how and the key I was give with my baby doesn't open it. I need help someone tell me how to get it unlocked! Lol
Locked hatch
Does the lever work? Sometimes my lever will feel like it broke off on the inside. I gotta climb in and on the passengers side up near the latch i gotta push a little bracket backwards(to the plate). Its the child lock i guess! ANyway i push that lever and she will open right up.
if the hatch is actually locked then i dont know what to do.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
there is a little lever that actuates the lock, usually the key is attached to a little metal arm that has a piece of plastic that can sometimes break. the actual lock will be a little lever under the doorcard, you should be able to get to it. It's happened to me before too, only problem is we had to use a broomstick because we cant fit through our cage :/. i know your pain on it lol
Car #789
Sponsors: Williams American Construction, Dewaynes Tire service, Roofing Supply Group
1992 Festiva L - BP Swapped, Aspire Swapped, Rally America Sanctioned.
1993 Festiva GL - 4sp Automatic and the bluest car i've ever seen...
http://www.facebook.com/warally
With a screwdriver, you should be able to move the finger at the latch mechanism from the inside. It needs to be pushed down.Trees aren't kind to me...
Here is a picture of the latch with the lever that they are talking about.
Here is a picture of the latch closed.
Here is a picture of the latch open.Last edited by bravekozak; 05-26-2017, 05:47 PM.
Hahaha same here!Originally posted by william View PostYou guys must have fat fingers! I just reach in there and push the lever! Lol-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
