I cant seem to find the beam width of the aspire vs festy. I need to make adapters to attach my fest ebrake cable to the aspire beam. I also need to add in the space for the camber plates on the one side. Does anyone know the extra width of the aspire beam?
Aspire vs festy beam width
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLDTags: None
I figured someone might just know it!
Nate said that the difference is all in the drums. The inner art might be the same and i only have to make the one e brake extension for the camber kit. Ill measure tonight tho.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Thank you1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Originally posted by Dragonhealer View PostThat could very well be true!
drum face to drum face (where the wheel mounts) the Aspire is wider by aproxamately 12mm per side.
I measured from what people are calling drum face to drum face - the part that has the 4 holes that the axle and brake drum mount to - and the distance between them on my axle (96 4-dr automatic) is 52-7/16-inch.
The thickness of the brake drum backing plate is 1/16" (on each side).
Hope this helps.
Originally posted by Doug Brown View PostI measured from what people are calling drum face to drum face - the part that has the 4 holes that the axle and brake drum mount to - and the distance between them on my axle (96 4-dr automatic) is 52-7/16-inch.
Hope this helps.
Edit: nevermind, I see you mentioned Aspire in post above.Last edited by RobotKarate; 06-10-2017, 09:00 AM.1999 Toyota 4Runner - daily beater
1993 Ford Festiva - SOLD
1986 Toyota Cressida - #stressida hmmmmmm SOLD!!
