I tried to do a search but am probably not typing the correct words to find something about this issue. I have everything set to come out of the A/C vent and the air will only blow out at the floorboard. Is there a broken vacuum line somewhere? Where can I look for it?
Only Blows out at the floorboard. Wont come out of the A/C vents on the dash
thank you I will take a look later today. I had thought for sure there would be a broken vacuum line but I couldn't find anything along the firewall like some of the other older cars I've owned in the past. I'll report back what I find.Originally posted by ryanprins13 View PostNo vaccum lines, all mechanical. Look in the passenger footwell towards the middle of the car and you will see the linkage. Follow it around to see what has broken or come loose.
Hot air does not come out of the dash vents. Not sure about A/C air though.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ac condenser (or is it the evaporater?) is before all doors and heater core, all the incoming air to the fan gets cooled, so cool air blows anywhere and everywhere.Originally posted by TominMO View PostHot air does not come out of the dash vents. Not sure about A/C air though.
I think he meant no air is coming out those vents.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 06-12-2017, 03:10 PM.
This a perennial question regarding Festivas. Hot air only comes out of the defrost vents and floor vents. Fresh air and air conditioned air will come out of the four vents in the dash. Heated air will not come out of these vents unless the system is modified to do so. And yes, it's all mechanical.
Top slider on the control panel establishes where the incoming air is directed. Far left directs the air to the dash vents, center to the floor, far right to the defrost.
Center slider on the control panel selects either fresh air (far right) or recirculation of cabin air (far left). Personally I have never used the recirculation setting, even in the coldest of Calgary winters.
Bottom slider selects the temperature.Ian
