I know this is a stupid question but .....does the transmission with the cv axles have to be in to just move the car with a car dolly from one garage to another. The distance is about 2 miles between the garages. My window is closing and the vehicle needs to be moved. I just want the put the rack n pinion, struts, lower arms and spindles back in put the tires back on to just be able to load the vehicle on to a car dolly to move to the other garage. Any issues or does the trans have to be back in?????
Moving Festiva question....
I use large bolts with washers that are just the right size to fit on the hubs. I bolt the hub together. I always have a car apart for some reason and do this allllllll the time. Bolt the hub together if you can. I have never had a festy hub come apart but i did have a jeep hub pull apart and boy did that suck.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Any time i replace an axle i keep the spare and cut them down to make short axles studs for this very reason. I have 2 festy ones in a box somewhere.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I just rolled a car out of the garage the other day with no axles and didn't even think about this... They were freshly installed hubs so hopefully the grease held everything in place lol"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
It can come apart with just the weight of the car or they can stay together for a long while. Ihad no option but to drive a jeep a mile with no axle. I made it! I tried to drive to just the store a few blocks away on a new bearing and it came apart. I think the old one was just so tight from years of being held together it just stayed together over the short drive. Now i dont chance it tho. I bolt it or put a shaft in it.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I never set a car down without stubs or bolts in place. I know festivas are not Volkswagens but the factory service manual for vw rabbit/golf says not to even put the weight of the car on front bearings without stubs as it can damage the bearings.I worked at a VW shop for 16years so I treat everything like it is a rabbit. Better safe than sorry.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
There was no engine or trans in the Car when I did it so hopefully it is fine. The Shifter dropped out pushing it back into the garage though..."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
