I currently have a b8-me swapped festiva and can't help but wonder if it actually has any advantage over the b6 sohc, does anyone know the weight difference between the two blocks ? My thought process is that you'daube get the same power to weight ratio but it would be easier on the transmission as you're pulling around less weight.
B8 vs b6 sohc weight
The slight difference in weight is almost certainly offset by the much higher HP of the B8. The extra weight is nothing when you factor in the total weight of the car.Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
