Power steering?
  • Power steering?
    My existing rack and pinion are almost worn out, and I'm curious what it would take to add power steering to my manual festiva.
    Do I just need something like this, and a pump? And where do I run power for it, if so?
    Don't get me wrong, Jack is incredibly easy to steer on the road, but backing it slowly into tight spaces for my job all day long can be a real bear.
    The Little Jack - 1993 L 5-Speed Manual
    Parts you'll need:
    -P/S Rack
    -P/S Pump w/ pulley
    -Bracketry
    -Hardware
    -Pressure/Return Hoses
    -Proper Belt
    -I remember seeing some discrepancy about the U-Joint from the steering shaft, but I don't recall the details; probably about a specific year
    You can use the Festiva power rack or the Kia Rio power rack(marginally softer/slower), both can be found in a wrecking yard but read up on the details regarding total length, tie rod inner/outer ends, etc...
    When removing the tie rods, count the number of turns as you take them off; full turns or half turns, either way, just be consistent and write them down so you can put them on the same to achieve proper toe (assuming it was proper beforehand)
    Make sure the rack is centered when you put it in so your steering wheel will be straight and so the spool valve will be centered (not a problem if you keep track of toe and it was already correct)
    It may take some persuasion to get the old rack out and the new one in, so be careful to not tear the new bellows, kink any lines, or mar any threads.
    Just slide it to one side, drop it down, and ease it out
    Would recommend going through all the bolt holes with a thread chaser (not a tap) and torquing properly.
    If any ball joints or bushing are worn, just replace them. I know every one makes a budget beater out of these cars, but this is safety we're talking about...
    If you like polybushings, you can find them at different auto retailers like Autozone, O'Reilly, and Rock Auto. A few people have said they make the ride stiffer, but with stock suspension, I haven't noticed any comfort difference. What I have noticed is that they've held up pretty well and I've put some hard abuse on them.
    If you have any questions:
    Feel free to ask
    Provide pictures whenever possible
    and remember
    The search bar is a valuable tool
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
      The biggest issue for me was to get a rubber boot off an Aspire to cover up the extended steering knuckle at the base of the steering column. That part has to be put on before the steering column is slid back into place.
      The pump is a Mitsubishi pump. Just look on ebay for one that looks the same.
      The first pump I bought could not be rebuilt. I would not build pressure. I had to throw it out.
      My v-belt pulley was from a Mazda 929. The pump is mounted above the A/C pump.
      Make sure you purchase a left hand drive power steering rack.
        My Festiva has 165/55-14 tires and the 2001 Kia Rio front strut tops. These tops have actual ball bearings, not just a thrust washer like the Festiva/Aspire tops have. That combination actually feels as easy as power steering. Took me a while to get used to, because it's so responsive. I'd recommend getting the Rio strut tops first, then see if you still want PS.
            @Everyone: Amazing info, thank you guys so much! I figured there had to be more to it, but searching the forums hadn't pulled up much for me and I'm still learning all this stuff from jump.
            Does it feel as easy while almost at a standstill? I have to back into these spots so slowly that I may as well be parked, because of people walking around or parking badly on either side of me.
            I plan to do a suspension and brake swap at some point (still running stock), but if that's going to help this issue that much then it's definitely getting bumped up the list.
              Anything over 2 or 3 mph turns my 175/65r14s smooth as butter with the Rio tops. Note I keep my tires aired up to 40psi, so that helps tremendously.
              1988 LX 5-speed
              Gone:
                How is your tread wear with that much pressure? I had my 155/80-12s at 35psi and was getting a little bit of extra wear in the center
                  Originally posted by Sid_RallyX_82 View Post
                  Parts you'll need:
                  -P/S Rack
                  -P/S Pump w/ pulley
                  -Bracketry
                  -Hardware
                  -Proper Belt
                  Feel free to ask
                  and remember
                  I forgot something:
                  -Reservoir
                    I have one Festy, a '91, with PS (and AC). Seriously, the only time I found it useful was when I had my right arm in a sling due to a nasty break. The PS made it easier to maneuver in parking lots.
                    I keep my front tires on my fleet at 35-36psi and do not notice any issues with center wear. I run about 30 on the rears and likewise see no wear issues. I can really feel it in the steering if I'm down just a few psi on the fronts.
                    Seriously, unless you have nothing to do with your time, I wouldn't mess with PS on a Festy. The same goes for steering column "tilt" which of course came standard in LXs.
                    88L black, dailydriver
                    88LX silver a/c, dailydriver
                    4 88/89 disassembled
                    91L green
                    91GL aqua pwrsteer
                    92GL red a/c reardmg
                    1952 Cessna170B floatplane
                      Like Tom said, try the Rio top hats before you go to all the trouble of finding/installing power steering. You use your Festy for work?? Dream job!!!!
                        Yeah, I'm gonna try that first. And I do! Most of my job is driving, so I alternate between my festiva and another car, depending on the weather or which one I'm working on at the time.
